The Genius Loci Δημοσιευμένο 19 Ιανουαρίου 2012 Share Δημοσιευμένο 19 Ιανουαρίου 2012 Zoom Introduces Its Most Advanced Guitar Pedal To Date: 18 Jan 2012 Hauppauge, NY – (January 19, 2012) – Zoom took the groundbreaking design of the G3 pedal and dialed it up a notch with the G5 Guitar Effects and Amp Simulator Pedal. The G5 combines the ease of a stompbox pedalboard and the power of a multi-effects pedal and USB audio interface, along with an extra LCD display/footswitch interface, Tube Booster, 3D Z-pedal, and additional amp models and effects. The G5 gives you the ultimate in control over your guitar tones in both stage and studio settings. The G5 offers four large LCD displays, each with a corresponding footswitch and parameter knobs, which form a graphical interface and allow you to utilize up to nine stompbox and amp effects simultaneously. Or use the pedal’s 20 super-real amplifier models, 100 world-renowned stompbox effects and over 120 built-in DSP effects to create your own sounds. The G5 also features a Tube Booster footswitch for adding up to 16dB of amp overdrive, as well as a 3D Z-pedal that lets you build highly complex sound control patterns or fully utilize the included 3D effects. And the pedal can store up to 100 of your original creations. In addition to housing a 60-second looper, versatile drum machine and auto-chromatic tuner, the G5 is a powerful USB audio interface. Bundled with Steinberg’s Sequel LE DAW for all your recording needs, you can also use Zoom’s Edit&Share software to create, edit, save and share your personalized settings on your computer. The G5 offers six hours of continuous operation on four AA batteries. It also features USB bus and AC power options. We’re putting our foot down with the most advanced pedal to unite traditional analog stomps with a multi-effects processor and amp simulator: The G5. http://techlaunchpad.com/zoom-introduces-its-most-advanced-guitar-pedal-to-date/ Model-o-phobia: something like homophobia, but much more amusing Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
soundmagic Δημοσιευμένο 19 Ιανουαρίου 2012 Share Δημοσιευμένο 19 Ιανουαρίου 2012 Καλά το 3 έχει 3 μέρη και το 5 έχει... 4? Ποιό τζιμάνι το σκέφτηκε αυτό??? Κατα τα άλλα σούπερ φαινεται στα χαρτιά. Με μια σωστή τιμή θα κάψει πολύ κόσμο! Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
The Genius Loci Δημοσιευμένο 19 Ιανουαρίου 2012 OP Share Δημοσιευμένο 19 Ιανουαρίου 2012 Καλά το 3 έχει 3 μέρη και το 5 έχει... 4? Ποιό τζιμάνι το σκέφτηκε αυτό??? Τι θα πει "μέρη"? 4 οθόνες έχει. Γιατί αλλιώς το επερχόμενο G8 (ω ναι), θα έπρεπε να έχει οχτώ οθόνες? ;) Model-o-phobia: something like homophobia, but much more amusing Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
soundmagic Δημοσιευμένο 19 Ιανουαρίου 2012 Share Δημοσιευμένο 19 Ιανουαρίου 2012 Ε τρία ίδια ανεξάρτητα modules τέλος πάντων, αυτό υποτίθεται είναι το 'thing' του G3. To G5 κρατάει το όνομα της σειράς και αλλάζει φιλοσοφία. Και καλά κάνει έτσι? Οπως τα λέγαμε και στο παλιό θεματάκι. Πολυ πιο ευέλικτο θα είναι. Καλα το G8 τι παραπάνω να κάνει? Θα έχει 2 πετάλια 2 λάμπες και θα είναι σαν hard case κιθάρας σε μέγεθος. It also features USB bus and AC power options. Αυτό σημαίνει θα τρέχει μόνο με ρεύμα από τη USB? Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
The Genius Loci Δημοσιευμένο 19 Ιανουαρίου 2012 OP Share Δημοσιευμένο 19 Ιανουαρίου 2012 It also features USB bus and AC power options. Αυτό σημαίνει θα τρέχει μόνο με ρεύμα από τη USB? Όχι, όπως το G3, είτε από USB είτε από μετασχηματιστή (ή μπαταρίες). Model-o-phobia: something like homophobia, but much more amusing Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
soundmagic Δημοσιευμένο 19 Ιανουαρίου 2012 Share Δημοσιευμένο 19 Ιανουαρίου 2012 Καλά χάλια το έγραψα! Ηθελα να πώ θα του αρκεί και μόνο το ρέυμα που δίνει η USB. Μια χαρά δηλαδή. Νομίζω βρήκα το επόμενό μου all-in-one μηχανηματάκι για σπίτι-PC! Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
The Genius Loci Δημοσιευμένο 19 Ιανουαρίου 2012 OP Share Δημοσιευμένο 19 Ιανουαρίου 2012 Καλά χάλια το έγραψα! Ηθελα να πώ θα του αρκεί και μόνο το ρέυμα που δίνει η USB. Μια χαρά δηλαδή. Νομίζω βρήκα το επόμενό μου all-in-one μηχανηματάκι για σπίτι-PC! Εγώ εμμένω στην άποψη ότι το G3 είναι αναντικατάστατο γι'αυτά που κάνει (μέγεθος, ευκολία, ποιότητα ήχου, routing). Χαίρομαι που άλλαξαν κάπως προσανατολισμό στο G5. Δεν βλέπω κάτι για MIDI βέβαια, πράγμα που με ανησυχεί... Όπως δε λέει και κάτι για inputs/outputs. Να δούμε και πόσο γκουμούτσα θα είναι, δεδομένου ότι έχει πετάλι. Λέγεται ότι έχουν αναβαθμίσει και το DSP, αλλά είναι φήμες προς το παρόν. Σίγουρα στο G8 πρέπει να το κάνουν. Model-o-phobia: something like homophobia, but much more amusing Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
metalmike Δημοσιευμένο 19 Ιανουαρίου 2012 Share Δημοσιευμένο 19 Ιανουαρίου 2012 Μπορεί να σας φαίνεται αστείο αλλά για 'μένα είναι μεγάλο + που έβαλαν (επιτέλους) σε μια μεγάλη πεταλιέρα drum machine...μακάρι να ακολουθήσουν αυτή την κίνηση και άλλες εταιρίες...για να δούμε...βλέπω τη zoom να πιάνει κορυφή πάντως...και φανταστείτε πως ήταν μια εταιρία που κάποτε την περιφρονούσαν όλοι (ίσως ακόμα και τώρα), άλλες φορές δίκαια αλλά τις περισσότερες άδικα... Για το G8 πότε να περιμένουμε πληροφορίες; http://www.facebook.com/dreambleedofficial Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
soundmagic Δημοσιευμένο 19 Ιανουαρίου 2012 Share Δημοσιευμένο 19 Ιανουαρίου 2012 Αν έχουν κρατήσει τη βασική ιδέα του χειρισμού θα έχει και το G5 την ίδια ευκολία. Ελπίζω τουλάχιστον. Το μέγεθος ναι ειναι μεγάλο πλεονέκτημα να μπορείς να το πετάς και στη θήκη της κιθάρας αν θες αλλά μεταξύ των δύο για εμένα είναι το G5. Το DSP γιατί λες θέλει αναβάθμιση για το G8 ειδικά? Metalmike η Zoom λέει drum machine το μετρονόμο. Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
The Genius Loci Δημοσιευμένο 19 Ιανουαρίου 2012 OP Share Δημοσιευμένο 19 Ιανουαρίου 2012 Μπορεί να σας φαίνεται αστείο αλλά για 'μένα είναι μεγάλο + που έβαλαν (επιτέλους) σε μια μεγάλη πεταλιέρα drum machine...μακάρι να ακολουθήσουν αυτή την κίνηση και άλλες εταιρίες...για να δούμε...βλέπω τη zoom να πιάνει κορυφή πάντως...και φανταστείτε πως ήταν μια εταιρία που κάποτε την περιφρονούσαν όλοι (ίσως ακόμα και τώρα), άλλες φορές δίκαια αλλά τις περισσότερες άδικα... Για το G8 πότε να περιμένουμε πληροφορίες; To G8 δεν είμαι σίγουρος ότι θα το δείξουν στη NAMM. Να σημειώσουμε ότι άλλο ανακοίνωση και άλλο διάθεση, έτσι; Η Zoom είναι γνωστό ότι ανακοινώνει προϊόντα όταν είναι ακόμα... στα μπετά. :D Αυτό με το drum machine: έρχομαι στα λόγια σου. Κάποτε διαφωνούσα κάθετα με το να υπάρχουν τέτοιες "μαθητικές" ευκολίες σε επαγγελματικά μηχανήματα. Αλλά μετά κάθισα και μελέτησα τι έκανε το GNX της Digitech (ένα προϊόν από τότε που ήταν σοβαρή εταιρεία). Και διαπίστωσα ότι το "όλα σε ένα" (είχε και multitrack recorder και looper φυσικά), έχει ΠΟΛΥ νόημα για κάποιον που συνθέτει, κάνει arrangements, βγάζει κομμάτια cover, κλπ. Το γεγονός δηλαδή ότι μπορείς να το κουβαλάς όπου θέλεις και να μην είσαι δέσμιος του υπολογιστή. Αν διαβάσεις σε ξένα fora, οι περισσότεροι λατρεύουν το G3 γιατί το παίρνουν... στη βεράντα, με ακουστικά και μπαταρίες και παίζουν ό,τι θέλουν με το looper, drums, κλπ, και με ποιότητα και "αίσθηση" που δεν τους απογοητεύει. Επομένως (έρχομαι πάλι στα λόγια σου) η Zoom το έπιασε το νόημα: απλές λύσεις, που να δουλεύουν, όχι φούμαρα, καλή ποιότητα, καλές τιμές. Εύχομαι να τους πάρει τα σώβρακα, έτσι για να ξυπνήσουν και άλλοι. Model-o-phobia: something like homophobia, but much more amusing Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
