ThS Δημοσιευμένο 10 Σεπτεμβρίου 2016 Share Δημοσιευμένο 10 Σεπτεμβρίου 2016 Versatile performance synthesizer with advanced ACB technology and 49 full-size keys Internal sound engine delivers classic analog tones and dynamic modern sounds with analog vibe Hosts up to three PLUG-OUT synths; JUPITER-8 and JUNO-106 PLUG-OUTs included Advanced low-pass, high-pass, and side-band filters with high-resolution controls Massive real-time control with dedicated knobs, sliders, and buttons Polyphonic step sequencer with classic TR-REC style interface Arpeggio, vocoder, and polyphonic Chord Memory functions CV/Gate outputs for interfacing with modular synths and vintage gear Large selection of onboard effects with hands-on controls USB audio/MIDI interface and control surface mode SPECS: Sound Generator Section Models SYSTEM-8, PLUG-OUT1, PLUG-OUT2, PLUG-OUT3 Maximum Polyphony 8 voices (MODEL: SYSTEM-8) (MODEL: PLUG-OUT1, 2 and 3 are depend on PLUG-OUT software) User Memory Patch: 64 (8 memories x 8 banks, per one model) Performance: 64 (8 memories x 8 banks) Structure Elements MODEL: SYSTEM-8 is as follows (MODEL: PLUG-OUT 1, 2 and 3 are depend on PLUG-OUT software) LFO Section Variation: 1 (Single LFO), 2 (Dual LFO), 3 (Resonanced Pulse LFO) Waveform: VARIATION 1: SINE, TRIANGLE, SAW, SQUARE, Sample&Hold, Random VARIATION 2: 6 types VARIATION 3: 6 types Knobs: FADE TIME, RATE, PITCH, FILTER, AMP Controllers: KEY TRIGGER, TRIGGER ENVELOPE Oscillator 1 Section Variation: 1, 2 Waveform: VARIATION 1: SAW, SQUARE, TRIANGLE, SAW2, SQUARE2, TRIANGLE2 VARIATION 2: 6 types Knobs: COLOR, MODULATION Source (MANUAL, LFO, P.ENV, F.ENV, A.ENV, OSC 3), OCTAVE (64, 32, 16, 8, 4, 2), COARSE TUNE, FINE TUNE Modulation: CROSS Modulator Oscillator 2 Section Variation: 1, 2 Waveform: VARIATION 1: SAW, SQUARE, TRIANGLE, SAW2, SQUARE2, TRIANGLE2 VARIATION 2: 6 types Knobs: COLOR, MODULATION Source (MANUAL, LFO, P.ENV, F.ENV, A.ENV, OSC 3), OCTAVE (64, 32, 16, 8, 4, 2), COARSE TUNE, FINE TUNE Modulation: RING Modulator, Oscillator SYNC Oscillator 3/Sub Oscillator Section Variation: 1, 2 Waveform: SINE (-2 octave), SINE (-1 octave), SINE, TRIANGLE、TRIANGLE (-1 octave)、TRIANGLE (-2 octave) Knobs: COLOR, TUNE Mixer Section Level: OSC 1, OSC 2, OSC 3/SUB OSC, NOISE Noise: WHITE Noise/PINK Noise Pitch Section Knob: ENVELOPE Depth Envelope: ATTACK Time, DECAY Time Filter Section Variation: 1, 2 Filter Type: VARIATION 1: LPF (-24 dB), LPF (-18 dB), LPF (-12 dB), HPF (-12 dB), HPF (-18 dB), HPF (-24 dB) VARIATION 2: 6 types Knobs: CUTOFF, RESONANCE, VELOCITY SENS, ENVELOPE Depth, KEY Follow, HPF CUTOFF Envelope: ATTACK Time, DECAY Time, SUSTAIN LEVEL, RELEASE Time Amplifier Section Knobs: VELOCITY SENS, TONE, LEVEL Envelope: ATTACK Time, DECAY Time, SUSTAIN LEVEL, RELEASE Time Effect Section Type: OVER DRIVE, DISTORTION, METAL, FUZZ, CRUSHER, PHASER Knobs: TONE, DEPTH Delay/Chorus Section Type: DELAY, PANNING DELAY, CHORUS 1, CHORUS 2, FLANGER, DELAY + CHORUS Knobs: TIME, LEVEL Reverb Section Type: AMBIENCE, ROOM, HALL 1, HALL 2, PLATE, MODULATION Knobs: TIME, LEVEL Other Section Knobs: PORTAMENTO, TEMPO Controller: LEGATO, TEMPO SYNC Key Mode: MONO/UNISON/POLY Step Sequencer Track 1 per Patch (step pattern is saved as a patch) Step 1 - 64 steps Recording Method Step recording, Realtime recording Controllers SCALE, PLAY MODE, GATE, SHUFFLE, FIRST STEP, LAST STEP Περισσότερες πληροφορίες και specs εδώ: https://www.roland.com/us/products/system-8/specifications/ Τιμή: $1499 Forgive me Lord for I have synthed.. Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
cos_dr Δημοσιευμένο 10 Σεπτεμβρίου 2016 Share Δημοσιευμένο 10 Σεπτεμβρίου 2016 μάλιστα!!! Πολύ πολύ ενδιαφέρουσα πρόταση στην κατηγορία. Για τις προσωπικές μου προτιμήσεις, περαν απο το εξαιρετικό sound engine και τους ηχους που αποδίδει με τη συνδρομή των εξαιρετικών............ plug out στο αντίστοιχο συνοδευτικο προφανώς software, χαρακτηριστικής "roland ποιότητας¨ που θα καλύψει τον χρήστη σε πολλά συχρονα μουσικα στυλ, στα συν υπολογίζω το vocoder, το ενσωματωμένο audio interface καθώς και την δυνατότητα να χρησιμοποιηθεί ως control surface. Για τύπους σαν........ εμενα (χαχαχαχαχχαχαχα) και το πώς συνηθως δουλευω, είναι πολύ εκλυστική πρόταση, για να το εχω σαν βαση ηχων και σαν controller για το software μου, αν μη τι άλλο και με το design θα ομορφύνει το home studio μου. δεν εβαζαν και κανα input παραπάνω, κανα instrument in, μιας και ειναι και audio interface. αυτα εκ πρώτης οψεως, θα το ψάξω παραπάνω, πολυ ενδιαφέρον φερτε μου ενα να το στιψω χαχαχαχχαχαχα O Influencer Των Συνθεσάιζερ Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
ThS Δημοσιευμένο 11 Σεπτεμβρίου 2016 OP Share Δημοσιευμένο 11 Σεπτεμβρίου 2016 Ένα πρώτο demo: Forgive me Lord for I have synthed.. Συνδέστε για να σχολιάσετε Κοινοποίηση σε άλλες σελίδες More sharing options...
