προβλημα με mesa boogie mark v
Fixed bias δεν σημαίνει ότι δεν θέλει ρύθμιση ή τουλάχιστον έλεγχο του bias, ίσα ίσα οι περισσότεροι fixed bias ενισχυτές έχουν τρίμμερ ή ποτενσιόμετρο για το λόγο αυτό.
Γεια,
απο το manual F-100.
Eχω αλλαξει δυο φορες σε boogie λαμπες και δεν πειραξα τιποτα.
Και επαιζε και παιζει σουπερ.
Well, there’s a short answer and a long answer to this question.
The short answer is that during my 12 years of repairing Fenders, one of the most frequent problems I saw was bias controls that were
either set wrong or that had wandered out of adjustment due to vibration. As any honest tech will tell you, there’s lot’s of easy money
to be made by sprinkling “holy water” on amplifiers ... uh, what I meant to say is “Your amp needed biasing.” See what I mean? What
customer is going to argue with that?
It only takes a moment and a volt meter: The Fender diagram shows how: “Adjust this trim pot for - 52 volts.” That’s it. Nothing more.
Now don’t be fooled into thinking that tubes “draw” more or less bias, they don’t. The way a bias supply is connected to a tube is akin
to a dead end road, it just trails off to nowhere without really completing a circuit. It’s a static voltage and regardless of what tube is in
the socket — or even if the tubes aren’t plugged in at all, it doesn’t change the bias voltage a bit.
So the end of the short answer is this: Since a bias supply needs to put out the right voltage and never vary, I wanted to build
amplifiers that were individually hard wired to the correct values and NEVER needed adjustment. And for 25 years, that’s how Mesa/
Boogies have been built.
Time to change tubes? Just plug our tubes into any one of our amps and you’re DONE. No tech needed. NO bills and no BS about
biasing. And most important: The bias is RIGHT because it can’t change!
metal και φραπε!!!!
  • Απαντήσεις 23
Εδω και κατι μερουλες μετα απο κανα δεκαλεπτο με τεταρτο εκει που παιζω κανει ενα τσαφ σαν να τον κλεινεις και τον ανοιγεις αμεσως και παιζει κανονικα και ξανα παλι το ιδιο.αλλες φορες δεν το κανει.καμια ιδεα;ηθελα να δοκιμασω αν φταιει καμια λαμπα αλλα οι boogie παιρνουν μονο boogie και λεω ασε μην γινει στραβη και τρεχω μετα.
To φαινόμενο είναι μάλλον λόγω τροφοδοσίας και φαίνεται να οφείλεται σε υπερθέρμανση κάποιου στοιχείου.
Καταρχάς, θα έλεγα να επιλέξεις τις 90W επιλογές κάθε καναλιού. Τότε, δεν συμμετέχει η λυχνία ανόρθωσης/τροφοδοσίας στο κύκλωμα (diode mode). Αν δε σου κάνει θέμα, τότε σημαίνει ότι θέλει νέα ανορθώτρια Electro-Harmonix 5U4GBEH .
Αν όμως κάνει θέμα και τότε, πάμε για άλλη αιτία...
Άλλο σενάριο είναι η θέση του bias διακόπτη στο πίσω μέρος. Έχει 2 επιλογές για λυχνίες 6l6 και el34. Δες τι τύπου λυχνίες φοράει ο δικός σου και βάλε το διακόπτη στη σωστή θέση πριν ανοίξεις τον ενισχυτή:
http://www.mesaboogie.com/Product_Info/Mark_Series/mark5Images/m5_fullrearpanel.jpg
Πάλι από το πίσω πάνελ, έχει ένα διακόπτη για τη λειτουργία ενός ανεμιστήρα (fan). Είναι ανοικτός ή κλειστός στο δικό σου? Αν είναι κλειστός, άναψέ τον και δες τι γίνεται. Με τις καλοκαιρινές ζέστες, μπορεί να είναι απαραίτητος για μερικά στοιχεία.
Αν τίποτε από αυτά δεν κάνει διαφορά, τότε θα πόνταρα σε πυκνωτές ηλεκτρολυτικούς. Μπορεί κάποιος να είναι στα τελευταία του (να έχει διαρροή το διηλεκτρικό του). Αυτό συμβαίνει συχνά σε πολλά μηχανήματα κι έχω πετύχει περιπτώσεις, τόσο λαμπάτων όσο και solid state ενισχυτών, με leaking πυκνωτές.
Όπως σωστά είπαν τα παιδιά, θέλει καλό κι έμπειρο μάστορα το συγκεκριμένο μηχάνημα καθώς είναι πολύπλοκο και ιδιαίτερο.
Συμφωνώ με τον Σοττο, και εμένα το στιγμιαίο "τσαφ¨μου ακούγεται σαν στιγμιαία κατάρρευση πυκνωτή στην αλυσίδα της τροφοδοσίας λόγω γήρανσης, υπερκόπωσης ή/και υπερθερμανσης. Σε κάθε τέτοια περίπτωση το πρόβλημα πρέπει να λυθεί από έμπειρο τεχνικό και να αποφευχθούν οι πειραματισμοί με υψηλές τάσεις.
Γεια,
Κακώς, εκτός και αν έβαλες Boogie λυχνίες. Αν δεν έβαλες Boogie απλά είσαι τυχερός που οι καινούργιες δεν ήταν overbiased.
Ολοι οι Boogie ειναι σχεδον cold biased απο το εργοστασιο οποτε οτι λυχνιες και να τους βαλεις δεν παθαινουν τιποτα,οι λυχνιες της Boogie ειναι μετριες και παντα καποιες καλυτερες ακουγονται πολυ καλυτερα ακομα και αν δεν πειραξεις το bias ...
προσωπικα ποτε μου δεν ειχα προβλημα οτι λυχνιες και αν εβαζα στους δικους μου (Mark 1 & Mark 3) φυσικα και οι δυο ακουγοτανε δραματικα καλυτερα με NOS 7581Α που ειναι ισως οι καλυτερες λυχνιες για τη σειρα Mark
Ολοι οι Boogie ειναι σχεδον cold biased...
Αυτό συμβαίνει στους περισσότερους ενισχυτές εκεί έξω!
Ωστόσο οι Boogie με EL84 είναι συνήθως hot-biased οπότε προσοχή. Μιας και λέμε, όμως, για Mark V, η Boogie δεν υπάρχει, το εργοστασιακό bias για 6L6 είναι προς cold ενώ για EL34 προς hot!  ;D
Ειχα βαλει ακριβως το σετακι JJ που προτεινε η boogie για τον F-100.Χωρις να πειραξω τιποτα.
Δεν ειχα κανενα απολυτος προβλημα.Τεραστια διαφορα.
Στον dual rectifier φοραω Tad(προσωπικη αποψη παντα,δεν υπαρχει καλυτερη λαμπα για μενα)
Ο ενισχυτης ειναι "αθορυβος".
Παιζω σε δυνατες εντασεις με αρκετο gain και χαμηλο κουρδισμα.
Δεν ακους το παραμικρο.
metal και φραπε!!!!
Κατ'αρχήν η παρουσία ή απουσία θορύβου δεν έχει σχεδόν καμία σχέση με το biasing. Δεύτερον, θα με ενδιέφερε να δω σε ποιο σημείο προτείνει (γραπτώς) η Mesa λάμπες JJ και όχι τις δικές της. Προσωπικά, η μόνη σχετική αναφορά σε άλλες λάμπες που έχω δει ήταν σε κάποια αρχαία manuals των Mark - πριν τον IIc - που πρότειναν Sylvania και GE (υποθέτω πριν ασχοληθούν με τις δικές τους).
Φιλε bloody_sunday μην μπερδευεσαι,
δεν ειπα οτι εχει σχεση με το biasing!!
Aπλα ανεφερα πως συμπεριφερετε η λαμπα!
Οσο για τις jj εφαγα τον κοσμο να θυμηθω το site που τις παρει(απο αμερικη)
αλλα δεν το βρηκα,εχει και δυο χρονια :(
Το  site ειχε απειρους boogie και συγκεκριμενα εγραφε οτι η ιδια η boogie
προτεινε τις συγκεκριμενες λαμπες για καλυτερα αποτελεσματα.
Δυστυχως δεν μπορω να στο αποδειξω γιατι δεν βρισκω το site.
Ψαχνω..
metal και φραπε!!!!
