Νέα από το Winter NAMM 2012
Κι εμένα μου άρεσε. Περιμένω να δω πότε θα βγει ένα guitar rig stand-alone. :)
Η Line 6 όντως πολύ προχώ. Να δούμε πώς θα δουλεύει.
  • Απαντήσεις 77
God damn it. Τώρα θα αναγκαστώ να το αλλάξω με το κανονικού μεγέθους, θα αποκτήσω ελεύθερο χώρο στην πεταλιέρα μου και θα πρέπει να ψάχνω για άλλα πετάλια  >:(.
Πέρα από την πλάκα, έχω την εντύπωση πως είναι το μοναδικό μικροσκοπικό pedal tuner που θα υπάρχει στην αγορά. Kudos to TC electronic.
Marshall 50th Anniversary 1 watt amps
JTM-1
2 x ECC83 preamp valves, 1 x ECC82 power valve
Loudness and Tone controls
Amber power indicator light and Vintage Power Switch
Original Marshall ‘Block’ Logo
Era correct cosmetics
8 & 16 Ohm Speaker Outputs
10” Celestion Speaker (combo)
Power Switch (1w > 0.1w)
Commemorative Rear Panel Plaque
Available January 2012
JMP-1
2 x ECC83 preamp valves, 2 x ECC81 power valve
Volume, Bass and Treble Controls
Authentic Red Power Indicator Light and Vintage Power Switch
Era Correct Cosmetics
Rear Panel Gain Boost Switch
10″ Celestion Speaker (combo)
Available March 2012
JCM-1
Preamp, Master, Bass, Middle and Treble Controls
Boost Switch
High Sensitivity Input
Available June 2012
JVM-1
Two Channels – Clean and OD (footswitchable)
Clean Volume, OD Volume & Gain plus Bass, Middle, Treble and Presence controls.
Channel and Resonance Switches
FX Loop
Emulated Line Out
Footswitch Included
8″ Celestion Speaker (combo)
Available October 2012
Guitars:YAMAHA SG1820,YAMAHA SG1802
Pedals:Jerry Cantrell Wah, Bogner Red, Bogner Blue, MXR 5150 Overdrive, Zoom MS-70CDR
AMPS:Yamaha THR100, Atomic Amplifire
Orange Micro Terror & PPC108
Orange Amplification is set to launch the Micro Terror at NAMM, the smallest model yet in the manufacturer's Terror range.
The new addition to the series features a single 12AX7 pre-amp tube with 20 Watts RMS of solid-state output, an auxiliary output for an MP3 or CD player and it can be plugged into any cabinet with 4Ohm or greater handling.
Also new from Orange is the PPC108 cab – a perfect partner for the Micro Terror. The eight-inch speaker produces a punchy tone, it utilises Orange's basketweave tolled grill cloth and it comes with Orange crest and badge.
ORANGE OR50 & OR15 New Amps
Specifications OR50H
Single Channel
Foot Switchable Master Volume/Attenuator
Three Band EQ
HF Drive Control with Boost
3 Stage Gain section
Classic 2 x EL34 valve configuration
3 x 12AX7
50 Watts RMS
Chassis mounted hand wired power valve sockets
Specifications OR15H
Single Channel
Three Band EQ
4 Stage Gain section
Classic 2 x EL84 class A valve configuration
3 x 12AX7, 1 x 12AT7
15 Watts RMS
Dimensions: 30 x 17 x 14 cm, 11 x 7 x 5.5 in
Weight: 7kg/15lb
* Edit: το θυμήθηκα - ήταν το Open Stomp Coyote 1.
Εχει και η Line6 ένα τετοιο αλλα το πουλαει μονο Αμερικη απ οτι εχω δει.
http://line6.com/tcddk/
Γραφεις σε Assembly αν θυμαμαι καλα, και με τη βοηθεια ενος προγραμματος και σε C.
Αληθεια το χει φερει κανεις?
Αυτά είναι:
http://www.guitarnoize.com/namm-2012-planet-waves-announce-cellu-glo-glow-in-the-dark-picks/
“Guitarists also love them because they are so easy to find on dark stages.”
Φαντάσου τον τσίπη κιθαρίστα στο "dark stage" να λέει στον ντράμερ να περιμένει για να βρει την πένα που του έπεσε...
I puked a little in my mouth...
NAMM 2012: Washburn Paul Stanley Acoustic Signature Model
http://www.guitarnoize.com/namm-2012-washburn-paul-stanley-acoustic-signature-model/
