Poly vs Nitro
Ενα πολυ ενδιαφερον αθρο του Mark Kendrick για το γνωστο θεμα...και την επιστημονικη φαντασια που εχει δημιουργηθει γυρω απο τα nitro φινιρισματα των ηλεκτρικων κιθαρων.....
"Mark Kendrick Master Builder @ Fender says.
Pardon my typos. I've lost alot of brain cells in my day. Could it be the 'Nitro'.
The first Fender lap steel was finished in black enamel. When Doc Kauffman and Leo formed K&F guitars in 1945, their original instruments, including the amplifiers, were finished in a lead based, wrinkle coat enamel. A nice shade of Battleship Grey. That was the only color available. After expermenting with different woods other than pine for guitars, they began using nitrocellulose lacquer. They used what was available to the furniture trade at the time.
The original colors were blonde, sunburst, etc... just like your Grandmas coffee table.
Custom colors were introduced in 1955. Once again they were enamel. The same material they used in the auto industry. The enamel would not adhere to the stearate based nitocellulose sanding sealer. Acrylic lacquers were then developed by Dupont to be sprayed on material other than metal. "Duco colors". In order for the paint to adhere, Fender began using a Sherwin Williams product called Homoclad. It was a penetrating, heavy solid, oil based sealer used as a barrier coat to to provide better adhesion for their guitars with custom colors. It was applied by dipping the guitar bodies directly into a 55 gallon drum, filled with the product. ALL Fender guitars produced after 1955 used this product until 1967, when Fender began experimenting with polyesters an undercoat.
By 1968, virtually all Fender guitar products used polyester as an undercoat, including necks. It's a two part product using Methyl Ethyl Ketone(MEK) as a catalyst. The reason the face of the pegheads were not sealed with polyester, is because type 'C' decals (under the finish) would not adhere to the product. While it is true a few guitars may have squeaked by with homoclad, when homoclad wasn't available, they used a Fuller O'Brian product called Ful-O-Plast. PLASTIC!!! It's obvious to me that those necks or bodies were stragglers, having to be reworked for some reason or another and not shipped after the change.
I'd like to make one thing clear... ALL FENDER GUITARS PRODUCED AFTER 1968 HAD A POLYESTER UNDERCOAT WITH A LACQUER TOPCOAT!!! There is no specific ratio. Enough poly was, and is sprayed to properly fill the grain while preventig a burn through while sanding.
In 1983, Fender began using polyuerthane as a topcoat. It cured quicker. It had better clarity. It had more depth and gloss, and didn't melt when you accidently spilled 151 on it. Fender then discontinued the use of polyester on the necks. Polyurethane is a 2 part product using a catalyst.
Fender has continued to use polyester, polyurethane, nitro, homoclad, and Ful-O-Plast.
Nitro is not a superior finish. An electric guitar doesn't 'breathe' at 120 db.
My first year at Fender I personally painted approximately 46,000 guitars. I like polyester. I like Nitro colors too. But maybe I'll let the players that use poly (ester or urethane) speak for themselves...
Billy Gibbons, Geddy Lee, Alex Lifeson, Joe Perry, Jimi Hendrix, Eric Clapton, Roccco Prestia, Jimmie Vaughn, Nils Lofgren, Vince Gill, Chet Atkins, Tom Hamilton, Lenny Kravitz, Merle Haggard, Don Rich, Darryl Jones, Mike Stern, Larry Carlton, Peter Frampton, Sting, Marty Stuart, just to name a few. More are available upon request.
Hope this helps,
Mark K.
Επειδή νοιώθω ότι αναφέρεσαι λίγο και σε εμένα που σας "έπρηξα" τον τελευταίο καιρό με το νίτρο...
πρώτα thanks για την βοήθεια (το πέρνω λίγο προσωπικά), αλλά δεν φτάνει μόνο αυτό. Το πρόβλημά μου είναι ότι έαν θέλω να κάνω μια personal κιθάρα και έχω φάει πολύ καιρό για να τη βάψω όπως θέλω (δεν μιλάω για ένα απλό χρώμα ή ένα απλό λουστράρισμα) (και εάν έχετε ασχοληθεί λίγο με αερογράφους πρέπει να ξέρετε ότι απαιτεί πολλή δουλειά και χρόνο και ότι δεν έχει undo!), δεν φτάνει απλά το λούστρο που είναι το τελικό στάδιο. :οπως κατάλαβα (από επισταμένες έρευνες) το ερώτημα ξεκινάει από το υπόστρωμα, μετά τα χρώματα που πρέπει να κάθονται στο υπόστρωμα και μετά το λούστρο που πρέπει να μην κάνει χημική αντίδραση με τα άλλα 2...άσε που χρειάζεσαι έκτός από έν ακομπρεσέρ και ένα αερογράφο και άλλα μηχανήματα...Κόλαση (Γι αυτό μπράβο ακόμα μια φορά στον exarhos για το εργαλείο που έφτιαξε).
Μαραθώνιος Εναλλακτική Σχολή
οχι,οχι δεν αναφερομαι σε εσενα :lol:
απλα ειναι μια πολυ ενδιαφερουσα ιστορικη αναδρομη που βρηκα σε ενα αλλο φορουμ (προκειται για την απαντηση που εδωσε η Fender για το φινιρισμα μιας κιθαρας σε εναν ιντερνετικο φιλο μου) :wink:
παντως εδω
http://reranch.com/
θα βρεις ΣΑΦΕΣΤΑΤΕΣ & λεπτομερεις οδηγιες για το πως βαφουνε με νιτρο ,ομως για αλλη μια φορα ΠΡΟΣΟΧΗ ,δεν θελουμε να σε χασουμε τωρα που σε βρηκαμε.. :lol: (σου μιλαω εκ πειρας μια και πριν απο μερικα χρονια την γλυτωσα πολυ φτηνα & καθαρα απο τυχη...βαφοντας μια κιθαρα με νιτρο... :? αγνοωντας τις προφυλαξεις που επρεπε να παρω)
Thanks man αλλά έχοντας 2 παιδιά και πλήρους επίγνωσης των ικανοτήτων μου, πιστεύω ότι θα μου έρθει πιό φτηνά (και θα έχω και καλύτερο αποτέλεσμα) εάν πληρώσω κατιτίς (έστω και παραπάνω) στον γνωστό επαγγελματία στο Ίλιον ή αν τη στείλω στις Σέρρες στον exarhos.
Στον Exarho στειλτην ,ειναι και αστερι παιδι οποτε θα παρει και καλα vibes το κιθαρονι!! :lol: :wink:
My first year at Fender I personally painted approximately 46' date='000 guitars.
[/quote']
Αυτές ήταν οι προτάσεις που μου έκαναν περισσότερο εντύπωση.
Για το πρώτο είναι η περίπτωση του "πες μας τι πίνεις και δε μας δίνεις". Αυτός μας είπε. Πραγματικά ελπίζω να κάνει πλάκα και να μην του έχει δημιουργήσει πρόβλημα το νιτρο.
Για το δεύτερο, η ηλεκτρική κιθάρα δεν αναπνέει γενικά.
Για το τρίτο, that's a lot of f#$%&^g guitars!
Και για να βάλω το μικρό μου λιθαράκι στη "διαμάχη" νιτρο-πολυ, όντας ο πλέον άσχετος με βαψίματα και βερνίκια:
Α. Έχω αλλάξει τα φώτα στη μεξικάνα strat μου από κοπανήματα μέχρι και τζαμαρία έχω σπάσει και δεν έχει καταλάβει τίποτα ακόμα. Απ'οτι καταλαβαίνω με τα νιτρο δεν θα ήταν έτσι τα πράγματα.
Β. Όλα τα λεφτά είναι στη φράση: ALL FENDER GUITARS PRODUCED AFTER 1968 HAD A POLYESTER UNDERCOAT WITH A LACQUER TOPCOAT.
Priceless!
Μη με ξυπνάς απ΄τις έξι...
