Νέα American Vintage μοντέλα από τη Fender
μπορεί κάποιος να μου εξηγήσει γιατί είναι πιο "σταθερά" τα veneer boards?
Από ότι οι ίδιοι οι άνθρωποι της Fender έλαγαν, στα slap board necks, επειδή υπάρχει μελαλύτερη μάζα rosewood πάνω από το maple, τα δύο υλικά είχαν διαφορετικές ανοχές και αντιδράσεις στην μεταβολή της υγρασίας..
Στα laminated roundlam necks, υπάρχει ουσιαστικά μια λεπτή φλύδα rosewood.. H κατασκευή είναι ελαφρώς πιο δύσκολη γιατί απαιτείται να είναι carved στο ίδο radius και το maple και το rosewood ...
Για περισσότερα, αναμένεις τον Superfunk να μας διορθώσει...  ;D ;D ;D  ;)
Όχι άλλα μινόρε...
  • Απαντήσεις 53
Φτανουν αυτα?
;D
http://www.usc.edu/CSSF/History/2010/Projects/J0207.pdf
http://en.wikipedia.org/wiki/Engineered_wood
Round-lam neck construction
Another atypical feature of the LTD Bent Top Tele is its round-lam neck, made from AA birdseye maple topped with a rosewood fretboard. Round-lam is an alternative to "slab" necks, which glue a flat fretboard to a flat neck. A round-lam neck uses a pre-radiused neck and joins it with a pre-radiused fretboard, normally thinner than a slab fretboard. Some guitarists claim that a rounded-lam neck lets more of the tone of the neck wood to come through (as opposed to the fretboard wood's tone), and also claim that it's a stronger construction method because there's more surface area for the glue used to join the neck and fretboard
The change from slab to round-lamination was to reduce problems (real or imagined, probaly real warranty issues) related to the different expansion/contraction rates of the two species. It was actully more expensive to make the laminated ones because they were radiusing BOTH sides of the rosewood and the top of the maple. It's not just a thin veneer bent to fit.
Part of the reason the Vintage Series instruments are '62 is because Bill Schultz et. al. were leaving themselves the option of going to round lam necks if they ran into problems with the slab boards.
Round lams are more expensive to make--they were an improvement.
If you've ever owned or even played an "L" series Strat you would know that they are (arguably, of course--we argue about everything) the best of them all.
"Slab" boards were suddenly popularized because SRV used them, and guitar players are sheep. "He's a powerful, dynamic and expressive performer, so it must be the fingerboard."
Τελικα δεν ειναι και τοσο ακριβες...
Και εξηγουμαι..
Για να παρεις απο τον Mark Jenny ενα αντιστοιχης ποιοτητας κιτ για να φτιαξεις μια 65αρα strat θελεις (μια και θα παρεις το κιτ με τον ακριβοτερο Musikraft λαιμο και θα πλερωσεις και κανα 200αρι παραπανω για rounlam & pearl dots)
$1100 για τα ...κσυλα και το hardware (μπορεις να τα παρεις και χωρις relic)
Μετα δεν θελεις και ενα σετ καλους μαγνητες?Πες οτι παιρνεις ενα σετ SD Antiquities ….αρα έχουμε αλλα $230.....
Βάλε και μεταφορικα ενα 140αρι δολλαρια εχουμε το συνολο $1450....
Θα πλερωσεις και ενα 30% δασμους και φορους αρα αλλα $435...
Το συνολον $1885 δηλ 1430 ευρω πανω κατω ΧΩΡΙΣ ΘΗΚΗ & ΧΩΡΙΣ ΣΥΝΑΡΜΟΛΟΓΗΣΗ ,FRET DRESS,NUT,ηλεκτρικα κτλ. (που αν δεν ξερεις να τα κανεις μονος σου θα σου πανε κανα 200αρι ευρω) αρα 1630 ευρω το τελικο συνολο.
Ο Θωμας εχει την 64αρα 1990 ευρω  αρα μιλαμε για διαφορα  360 ευρω εκ των οποιων αν βγαλεις τα 150 που κανει η θηκη και τα λοιπα τσιμπραγκαλα πεφτουν στα 210 ευρω...
Καθολου κακα αν σκεφτεις οτι αν θες να ΠΟΥΛΗΣΕΙΣ την partscaster θα την δωσεις το ΠΟΛΥ ενα 700αρι και την RI  ΑΝΕΤΑ στα 1200-1400....
φατε τωρα και ενα φανταστικο ντεμο της 64αρας tele για να αρρωστησετε και αλλο
;D
Τα demos του nstuffmusic που παίζει αυτός ο τύπος, έχουν μακράν τον ωραιότερο ήχο που έχω ακούσει στο youtube όσον αφορά τις παρουσιάσεις οργάνων. Άσε που είναι και παιχτρόνι ο καράφλας. ;D
Ιδού άλλο ένα πολύ ωραίο με τις στρατ που δεν έχει καθόλου μπλα μπλα.
Ενωμοτάρχης
