Platform / Smart Engineering (by Behringer)
«What is Platform or Smart Engineering? We are often asked how we design synthesizers. We’d love to give you some background as this is actually pretty cool.
Rather than reinventing the wheel every time we start a new synth, we first build platforms, a methodology that is very common in the automotive industry, where several cars share the same chassis, engines, door handles etc.
You may have noticed that for example we use several standard enclosures across our synths and drum machines. Reusing existing building blocks or platforms, dramatically speeds up development and reduces engineering and manufacturing cost. This is also the exact reason why we’re developing so many products at the same time. We currently have a roadmap of over 100 synths, drums, sequencers, midi keyboards etc. and right from the start, we decide on common power supplies, microcontrollers, keybeds, USB/Midi interfaces etc.
The image here shows a new platform, which one of our 7 synthesizer development teams has developed. Like you have seen with the Micro and Mini synths, this is now the Macro synth platform, which focuses on high power hybrid synths, based on an extremely powerful signal processor, that allows us to run some of the most complex granular or waveform synthesis algorithms. In fact we made it so powerful that it could even run multiple synths concurrently.
Unlike some of our competitors who simply use a Raspberry PI computer, we go the extra mile to deploy industry-grade embedded microprocessors. As you can imagine, developing this complex platform is extremely time consuming and expensive. However, once this platform is completed, the next synth development will require around 60-80% less work.
This principle is called platform or smart engineering and over the past 30 years, we have spent huge amount of effort to master this discipline. This is one of many reasons, why we can offer our products at much lower prices.»
Τα παραπάνω (και άλλα πολλά) θα τα βρείτε στην επίσημη σελίδα της Behringer στο Facebook, καθώς και διάφορες ερωτήσεις και απαντήσεις πάνω σε τεχνικές λεπτομέρειες. Η συγκεκριμένη εταιρεία είναι ίσως η μοναδική που εδώ και χρόνια έχει ανοίξει διάλογο με τους υποψήφιους/υπάρχοντες πελάτες της και παίρνει πραγματικά υπόψη της τις διάφορες προτάσεις και υποδείξεις τους για μελλοντικά της προϊόντα, και ιδιαίτερα στον synth τομέα.
Specs talks, M🐮🐮gs walks
Εντάξει. Καλά τα λέει και πολύ ωραία ακούγονται όλα αυτά από την πλευρά τους αλλά στην τελική δεν είναι ακριβώς έτσι τα πράγματα.
Υπάρχουν πολλές πτυχές και με αποκλίσεις. Εκτός αυτού υπάρχουν και τα copyright.
Μάλλον - σίγουρα δηλαδή, απευθύνονται σε άλλο ή πολύ συγκεκριμένο κοινό.
Ερώτηση.
Μήπως δεν έχουν εξειδικευμένα άτομα και ψάχνουν ιδέες από τους καταναλωτές; Λέω τώρα...
3 λεπτά πριν, Μανώλης Χναράκης είπε
Εκτός αυτού υπάρχουν και τα copyright. Μάλλον - σίγουρα δηλαδή, απευθύνονται σε άλλο ή πολύ συγκεκριμένο κοινό.
Ποια "copyright? Και σε ποιο ακριβώς κοινό απευθύνεται?
7 λεπτά πριν, Waterfall-K mk2 είπε
Copyrights & Pattents.
1 λεπτό πριν, Μανώλης Χναράκης είπε
Δεν βλέπω τι σχέση έχουν τα Copyrights & Pattents με τα παραπάνω. Το κείμενο μιλάει για συγκεκριμένα πράγματα.
Πως δεν έχει σχέση;
Αν μπεί κάποιος χψ και ζητήσει υλοποίηση κάποιας δυνατότητας ή κάποιων δυνατοτήτων από κάποιο γνωστό μηχάνημα γνωστής εταιρίας που είναι πατενταρισμένο, ο πιό πάνω κατασκευαστής (πχ Behringer) θα το υλοποιήσει;
Απλά ερώτηση κάνω.
Υ.Γ.
Συγγνώμη για το Pattents, Patents
9 λεπτά πριν, Μανώλης Χναράκης είπε
Mα ποιος ζήτησε απ'τη Behringer μια "υλοποίηση κάποιας δυνατότητας ή κάποιων δυνατοτήτων από κάποιο γνωστό μηχάνημα γνωστής εταιρίας που είναι πατενταρισμένο"? Τι συζητάμε τώρα? Η εταιρεία ανέβασε την παραπάνω φωτό στη σελίδα της και (μας) εξηγεί Τι είναι και που θα χρησιμοποιηθεί.
"The image here shows a new platform, which one of our 7 synthesizer development teams has developed. Like you have seen with the Micro and Mini synths, this is now the Macro synth platform, which focuses on high power hybrid synths, based on an extremely powerful signal processor, that allows us to run some of the most complex granular or waveform synthesis algorithms. In fact we made it so powerful that it could even run multiple synths concurrently."
Εντάξει. Ο χρόνος θα δείξει.
Απλά διαβάζω πίσω από τα γραφόμενα.
Επαναλαμβάνω, ο χρόνος θα δείξει.
 Ενταξει, λιγο πολυ ολες οι εταιριες το ιδιο κανουν, ανακυκλωση τεχνολογιας, ειτε σε hardware ειτε σε software επιπεδο. Δε βλεπω που κολλανε τα θεματα του copywrite.
 Τωρα το τι ακουει και το τι οχι η behringer, αυτο ειναι συζητησιμο, αν δεν της αρεσει παντως αυτο που ακουει απειλει και με καμια μηνυση, οπως τοτε στο gearslutz, οποτε εγω δε θα της μιλαγα 😆
 Γενικα το συντριπτικα μεγαλυτερο μερος των εταιριων μουσικης τεχνολογιας ειναι για τον λουτσο καβαλα, ουτε ακουνε πραγματικα το κοινο ουτε τιποτα. Μονο να ανακυκλωνουν τεχνολογια του 1821 ειναι ικανες, και να τη χρεωνουν τον κουκο αηδονι.
 Ηρθε ομως η ιπταμενη λουτσα απο τις πραγματικα μεγαλες εταιριες τεχνολογιας, intel, microsoft και τετοια, και τωρα τρεχουν και δε φτανουν. Οι αλητιες τελειωσανε, που χρεωναν την τιμη ενος server για ενα reverb rack, γιατι και καλα "εχει εξωγηινο processing power μεσα φιλος, και αλγοριθμους απο τη NASA", και στην πορεια ειδαμε το φως το αληθινο, ενα laptop του κατοσταρικου με freeware του γτμ.
 Και αν δεν ηταν οι κολλημενοι με τα αναλογικα, και ταυτοχρονα αν δεν υπηρχαν και οι παντα σεβαστες live αναγκες, θα ειχαν κλεισει ολες, και καλα ξεκουμπιδια θα τους ευχομουνα.
Τα ηλεκτρονικά κυκλώματα πολύ σπάνια μπορούν να κατοχυρωθούν με copyrights, για αυτό και όλα τα πετάλια πχ είναι μια συνεχής ανακύκλωση των ίδιων schematics.
Υπάρχει όμως πάντα θέμα στην δημόσια εικόνα μιας εταιρίας αν κοπιάρει πχ τεχνολογία από άλλη, που φυσικά τους απασχολεί εφόσον απευθύνονται σε δυτικό κοινό. Κλασικό παράδειγμα η Danelectro που είχε βγάλει ολόκληρη σειρά από πετάλια που είχαν schematics από δημοφιλή πετάλια άλλων κατασκευαστών, και μετά από αντιδράσεις αποφάσισε να τα τροποποιήσει.
